Hi
I own E300TD 1998 and reasonably happy with its clarance and the car has been driven through various dirt roads with no apparent problems. With no passeners/load the clearance as measured as distance between the road surface and outer shell of the car just after the front wheel arch (I noticed it is about the lowest point in bodywork) is 15cm.
I am considerin buying this avantagrde (Mercedes-Benz E Class E320 CDi Avantgarde 5dr Tip Auto Diesel Estate 3.2 2002) but low clearance concerns me - it is about 10cm. I understand that Avantgade is supposed to be lower but by about 1.5cm not full 5cm. Does it mean the car was modified by lowrin it further? Or does it mean it has some problems? How much would it cost to put it to proper clearanc so that speedbump / country dirt roads were not a threat for the car?
