OP
OP
Deleted member 2227
Guest
I swapped mine from pre facelift to facelift xenons, they are plug and play if you don't want the auto leveling and wash . They will need to be coded after you have them fitted.
I was going to look into the leveling but quite a bit of wiring needed. If you do the swap don't forget to block the vacuum line or you will get a hiss from the dash.
Can you explain what hiss and what vacuum line? cheers
