Wheel alignment help
Spera
WIGAN
2002 E CLASS 270CDI AUTO AVANTGARDE
Hello to all on this glorious sunny day.
I have just had the front tyres 18'' 245/40 changed on my Avantgarde 2003 w211 E270 cdi the rears are 265/35/18these are fine. The front tyres had good tread but had worn terribly on the insides towards engine bay. It was also pulling to the left more than it should. It had had the tracking etc done at National Tyres twice prior to above problem. I complained to them and they said you need to take it to a main dealers as they use weights and different equipment etc.They wouldnt do them again with a guarantee. I have asked two local garages regards alignment and they couldnt say if there was a different way/tools to do the tracking etc.
After searching the forums it seems there are different tools for the job, can anyone recommend a specialist known to be good anywhere near the wigan area or in the north west thanks sil.
You need a 4 wheel alignment done, not just tracking. Maybe a camber angle out of spec :thumb:
Have a look at the "centre locator" here: www.AlignMyCar.co.uk
Of the 5 that come against Wigan, I have used Jeffreys for tyres and they damaged the wheels so I wouldn't go there. I did also speak to the one in Liverpool, and they seemed to know what they were talking about. However I was down South with work so took the chance to go to Wheels-in-Motion and they did the alignment.
I had exactly same issues as you've mentioned, plus the car never felt "planted". Tony at WIM found the set-up was actually pretty good except the front toe-in was miles out, but was equal on both sides, as if it has been set like that on purpose (car was ex-MB and 6mths old when I got it).
Toe out wears tyres on the inside edge; toe in on the outside edge. Toe in makes the steering easier and viceversa.
Hitting potholes, kerbs etc can upset the toe in, but if you don`t recollect anything like that, the most likely cause of your tyre wear is deterioration of the lower wishbone suspension bushes.
This allows negative camber to develop, and the problem is doubled because the steering trackrod can`t move outwards, and so toe out increases.
New MB bushes are readily available, but pressing the old ones out and new ones in is a bit of a pain. I know. I`ve just done mine. New lower wishbones complete with bushes are available, and will probably be the cheaper option if a garage is used. :thumb:
Sorry, brain fart! You're right of course - my tyres were worn on the outer edges. It was suggested it might have been set with a lot of toe-in to try to increase straight-line stability.
ive read on here somewhere that mercs have to be preloaded with 80 kilo weight on passenger seat for alignement to be done, also they dont have adjustable nuts and aftermarket bolts allow for them to be adjusted
Regarding the pull there is some information i wrote here> http://www.mbclub.co.uk/forums/wheels-tyres/98176-definative-explination-pull-left.html
As for the tyre wear it's a little more complicated.
Line of sight?
The fast-fit industry has misinformed and misunderstood what they offer and how to apply a solution, i know this because i train them and their instructors and each time it worries me what the public had been given prior to the training and even after training i know the flow of staff within fast-fit is so rapid applied training is nothing more than a company statement!!
To the point
In my little mind it's better i train you? Not in all the technical theory and chassis dynamics, more the points that relate to this forum and members historic complaints.... So
As said line of sight, what are they offering? ( topic taken from the wim forum ) the paper is not copyright so feel free to use.
Tracking/Alignment
Is linear, this measurement shows no concern for any other angle. This form of measurement is the most common in the World and the most damaging.
Angles measured 1
Four wheel Alignment
Uses the rear wheels as a scale to centre the steering rack.... then the front toe..... this is better but is assuming the rear is centred.
Angles measured 2
Four wheel Laser Alignment
Same as above.... be wise!
Geometry/Primary
Will image the exact rear centre line to permit a centred steering wheel.. additionally the front and rear camber positions will be measured. This is the most common form of Geometry and i consider this as 'basic'
Angles measured 8
Full Geometry/primary and Secondary
Is absolute but harder to understand. Few places even with the equipment measure the Secondary angles, these include...
Castor
KPI/SJI/SAI
Scrub radius
included angle
TOOT/Ackerman
Delta curve
and so on
Most areas that involve rapid tyre wear or handling issues need to be read from the 'Secondary' data, even more important if the car has been modified or for diagnostics after an accident.
Angles measured 15+
Not easy reading indeed, millions of pounds change hands every day for 'Alignment', a need to be wise could save you £ssss
One more thing to make the 'blood boil'.. The Primary and secondary Geometry has a customer destination?
1: Primary is the 'dumb' customer version
2: Secondary is withheld unless requested and named the 'Technicians version.
Given the link to the "pull explanation" and method of measurement required we are reasonably prepared to solve your complaint.
1: The MB DOES NOT need to have ballast installed, this is a myth or a fast-fit cop out. MB's on air suspension do need to have the level locked at mid "bump/ droop" but other than that and some fluid requirements the vehicle is unladen.
2: During the preparation parameters for a FULL geometry the machine will ask for the ball point angles? These are the perpendicular positions of the front lower wishbone and drive shafts, the reason for this is as the suspension coils age they also sag, this change will change the dynamic position for the geometry and MB offer matter of fact positions for the static condition.
Reads overwhelming but it's not, it's a simple task within the realm of chassis calibration many manufacturers ask for.
3: If you MB had the historic pull to the left a misinformed technician may have blindly thought changing the front Toe angle away from the curb would belay the pull, this is simply not the case but typical of the fast-fit template.
4: As seen from the line-of-sight explanation above "tracking and four wheel alignment" are a conn, problem we have is most fast-fit companies and misinformed public don't realize tracking is a shared angle albeit in the right position or wrong position, this said it's symmetry cannot allow a pull.
Example
A: A correctly aligned cars front wheels in motion, looking from above would be like this | |
B: An incorrectly aligned cars front wheels in motion toed out would look like this \ /
C: Same thing but toed in / \
D: What you cannot have is longitudinal dynamic ( in motion ) toe looking like this \ | or / |
E: In the event "someone" has attempted to off-set the toe position all you will have is an off-line steering wheel, simply because as a driver you regain symmetry in order to drive forward.
Wear pattens
The type of wear is a definitive clue to the problem. There are exceptions but as a rule we have this....
1: Wear confined to around 10% of the total tyre width, front/ rear and smooth is camber.
2: Wear involving around 10% ( more if profoundly misaligned ) and rough is Toe related.
3: Wear that's smooth on the front tyres and rolls onto the sidewall is Castor related.
4: Wear on the rear tyres that ungulates up and down is Toe related. This type of wear is unofficially called "heel and toe".
Further reading
If you want to see some of the horrors i see have a glance here> Wheels-InMotion -> Horror Of The Week
Some really good information about the MB suspension can be found here> Mercedes-Benz: Alignment/Chassis Diagnostics from Continental Imports
My approved centres can be found here> Buy Tyres Online UK Fitting Centres | Blackboots Wheels in Motion although if you need our support you would need to buy online.
Would that extend to New Zealand by any chance Tony??
The geometrical laws are global, continental application due to road configuration would differ as would temperature variations but as a general rule my observations could be read into most owners complaints.
Seems like a very "taboo" topic but it's not. Applying the laws within chassis dynamics is crystal clear providing those in control know what end of the intelligent fuse to light? Historically within the multi-million pound car industry those serving us! struggle to understand this.
In this bitter cut throat deficient world we, you and me need to be on guard, because this reasonably technical topic if applied wrong could cost members much £sss
I feel as said it's better to give the members a "heads up" on the topic and know what you/ they are paying for, expect nothing more than a solution, whoever is calibrating the chassis.
Thanks to all for the posts , been very helpful. Forgot to add that my steering wheel is off centre slightly to the left. Will book it in to one of the recommended and let you all know the results.
Thanks Tony but I meant your fine Consulting Services. My cars have never run straight as long as I have had them, one since early 06 and it has been to many people. I've given up on the basis of I firmly believe they have no real idea on stopping this left drift. But it is time for tyres etc soon and it would be nice if you could educate the MB Dealership here to help them get it right. I have had a chat to the guy who does the Alignments, given him your web site address and he is happy to work with you over the phone if you are happy. There really is no other way Tony, except for sticking with cheap tyres and replacing them regularly, unless you fancy a trip to NZL for the RWC or just for a break when Summer arrives later in the year.......
Pull to left
Line of sight?
To the point
Tracking/Alignment
Angles measured 1
Angles measured 2
Geometry/Primary
Angles measured 8
Castor
KPI/SJI/SAI
Scrub radius
included angle
TOOT/Ackerman
Delta curve
and so on
Angles measured 15+
Example
Wear pattens
Further reading
Hi Tony,
I wonder if you could point me in the right direction here please.
I have a w203 estate on an 05 plate and recently had the drivers side lower control arm with the ball joint in it fitted as the old one was worn. Since fitting, I have noticed that the car pulls to the nearside.
Typically, i had the alignment checked using the laser technology but having read the post above, this was possibly a waste of money. The pull to the nearside remains and the steering wheel is not dead centre.
Is this something that your team would resolve from the steering geometry perspective or should I be thinking more of changing the other (nearside) track arm, so that both would then be new.
Incidentally I didn't buy the Lemforder made control arm but another from Euro car parts around 3/4 of the lemforder price.
I have noticed that there is a tiny bit more wear to the outside edge of the nearside front tyre that the offside tyre at the same edge....about 1 mm. 9Not sure if this is significant) The tyres are only 3 months old
Any thoughts would be much appreciated.:thumb:
shame if your wear is making you buy cheap tyres for such a good car.
that will likely cause the problem to be doubled, as cheap tyres are often known to go off quickly in terms of their geometric abilities.
If you are willing to get knowledgeable about the subject yourself, you can at least save yourself a lot of grief by buying a sliding tracking board, and doing some adjustments yourself.
Whilst I have been intending to visit Tony myself and never getting around to it, i have been using the slding board with great success over the last 10 years on the E320 Merc (1995 124).
At least I know that my wheels are all pointing in the right direction, and along with a simple cheap camber gauge, that is more or less taken care of as well.
NIL abnormal tyre wear is experienced, and I get that planted feel and slip to nearside of road is very gradual.
Is it a physical pull or is it the case it pull when you straighten the steering wheel?
I have to keep a fairly strong hand on the right hand side of the steering wheel. If i let it off on a straight piece of road with minimal camber it will fairly quickly pull the car into the hard shoulder. I have heard that UK cars are set up to eventually default to do the nearside gradually but this is more severe. I noticed it as soon as I had the offside lower track arm(with integral ball joint) replaced. Hope this helps
Regards, tim
Reads like the typical MB castor pull, your going to need a geometry done i'm afraid. As for a designed pull in the UK that's rubbish.
Many thanks, I apppreciate your advice. Finally please ....what sort of money would it cost to have this type of correction done. Could you advise.
