wheel bolt help w210
crash406
manchester
C270 CDI AV ESTATE
fitted 18x8 with an offset of 35 what size wheel bolts should i use the ones off the original alloys are to long?:confused: for the rear any help would begrateful.
As a guide you need bolts the have 18 mm sticking out of the rear of the wheel when the bolt is all the way in.
and very important is to make sure the friction seat is the same type on the bolt as it is on the wheels or they may self loosen at worst or damage the wheels at best. Any more than 21mm bolt penetration and you risk damage to handbrake mech on the rear.
