Wheel bolts - stuck (for good?)
t567wab
Croydon
Vito 122 Sport X
Few months ago I've had an emergency on a motorway abroad - puncture.Cut the long story short I've broken 2 wheel spanners and 1 ratchet trying to undo the bolts there.
Is this a common problem in Vito or even other models?:dk:
Just want to find a solution if there's any...
I had similar problems years ago. It was tyre garages over torqing wheel nuts with air tools. I bent spanners while jumping on them trying to undo the nuts. Ended up back at the garage not best pleased. They undid with air tool and tightened by hand with my tyre lever.
Garages seem better now. they use copper slip, and set torque on air tools correctly, but i still check i can get the nuts undone ... just in case.
In my case every time I have to deal with my tyres/wheels is always the same problem.Last time thet couldn't ever undo them with airgun.The bolts just tend to tight themselfs up.
In 1991 I bought a new Honda CRX. And I was unfortunate enough to suffer a flat very early on in the piece.
I found the factory provided tool kit wasn't much help, those miniature tyre irons don't give you any leverage.
I remember thinking how feeble it would be to call the road service, so I rang a mate who I knew would be passing by shortly. He's a big burly Italian guy.
No surprise, he made a few jokes at my expense before he went to try his hand at the tyre iron. But the nuts were so locked up that he actually lifted the car off the ground when he gave it an almighty hoik!
So after he failed, I felt okay about calling road service. The guy tried a pole on the end of my tyre iron but that failed too, so all he did was put air into my tyre and told me to scoot straight back to the dealer to sort out, which I did.
The service guys ended up cutting the nuts off, greasing the studs and put new chromed nuts on as replacements.
And if all of the above wasn't bad enough for one morning, silly me had actually phoned the office and told them where I was and what was happening... so by the time I got in to work, the whole place wanted to know what it was like to have your nuts cut off and if I was happy with my chromed replacements!
