andy_cyp said:the more the offset the more the wheel will stick out.
example et30 as opossed to et34 means that the latter will stick out 4mm than the other, basically the hub of the rim is thicker.
mickl said:would spacers bring the the wheel out?
jgevers said:Yes they would but might give balance problems with unwanted vibrations as a result. Always better to have wheels with the correct ET value.
Different ET value can give geometry design problems like bumpsteer, rollcentre to centre of gravity ratio increase, etc. etc.
You can buy spacer kits from companies like Eibach and H&R. My personal view is that they are just hassle.
regards,
Job
mickl said:hmmm. decisions decisions. Might have to go back to the style II rims.
Mambo said:You know it makes sense![]()
Murray Systems said:There is a range of acceptable offset values for any car. Mercedes have quite large ranges in offset. Both ET30 and ET34 are valid ET values and none require spacers.
