Stratman
I had a visit to Wheels In Motion today, to sort out the famous pulling to the left.
After Joe had put it on the lift and hooked up the rather amazing measurement and alignment centre, it showed everything was in the green and within MB's specifications. This is perfectly normal and part of the reason they pull. As is much better explained on the WIM website, because of British road camber the castor angles need to be offset.
Joe installed the famous adjustable bolts, worked his magic with the machine, took it for a test drive and pronounced it much better.
The drive home included town and country roads plus motorway so was a good test. It is certainly better, no doubt about that, but is still somewhat reactive to road camber but to a lesser degree. Joe explained the Mercedes suspension angles make it sensitive to tyre type and tread wear. He recommended swapping the fronts side to side to see if it improves further. He also cautioned that new tyres (which will be needed sooner rather than later) may change things a bit again. Given that the bolts have fixed adjustment positions rather than being infinitely tweakable, the improvement is as good as it's possible to achieve.
So is it one hundred percent cured? No, I'd say there's about an eighty percent improvement but it is far more relaxing to drive and without doubt worth it.
A big thank you to Joe and the rest of the lads, who were happy for me to watch the process and ask questions. They are friendly and efficient and I'd not hesitate in recommending them.
