which gearbox dipstick?
meri_gadi
hi there all,
i wana check the oil level myself on my E320 cdi W211. i have a dipstick i bought to check the oil on my W140 S280.
Would i be able to use that dipstick or i have to get a new one?
thanking in advance. Jav
Not 100% sure, but I would say that the length and markings on the oil dipstick will be different to the gearbox dipstick.
What you should do is take your oil dipstick to the shop, and before buying the gearbox dipstick, compare the 2 lengths and the markings. If they are the same then do not buy it.
Otherwise if you really want to save a buck, what you can do is go to the shop with a brass wire and a hacksaw. Bend one end into a circle (for the handle), then cut the wire to the exact length of the gearbox dipstick and use the hacksaw to make a Min and Max marking.... voila... you've made your own dipstick :-)
I bought (from Merc) a gearbox dipstick for my W211 320CDi. It's part No is............W1405891521 00
Sounds to me like what you've already got.
