Which grease for wiper mechanism?
That will probably do the trick although personally, I would use a lithium based grease but that's my preference
If you haven't bought the grease yet, you would be better off getting a high melting point variety. Not that the wipers need it, rather it will be more useful for wheel bearings and CV joints.
Halfords do Castrol LM which will do nicely.
Hellfrauds also do a CV joints one , so is this the same as the Castrol one, just unbranded?
The 'Lith' bit probably means it's lithium based, so there's a good chance it's similar.
99% of easily available greases are lithium based...
Nope. High melting point greases are for high temperature applications - kilns, ovens, etc.
And CV joints and wheel bearings are better served with a high load bearing (EP) capacity.
What you would be better with is a a waterproof grease if the mechanism is exposed to the elements, otherwise a standard run of the mill grease will do.
There are far too many myths surrounding grease application.
Wow! Didn't realise there was so much variation in grease options.
So Helldrauds are no good then?
Where do I get a silicone based product from?
you can get it from a plumbers shop . they use it for lubrating the rubber seals on the 4 inch underground pipes / but make sure its the original silicone grease type. nowdays they may sell you a sparay or iquid type which may be not be silicone type.
I brought mine from B & Q about 5 years ago.
Try Screwfix who are a sister company of B & Q and sometime cheaper .
before you buy may sure the tin says its silicone grease and not silicone subtitue.
Just looked at the daiwa reel greaser suggested by compress ignite . This product should be ok but looking at it I think is basically sillicone grease as silicone has the same properties as compress ignite mentioned .
correct me if I am wrong.
Apologies for brevity of my earlier post - I was in a rush...
There are more grease thickener base types and variation in base oil than you can shake a stick at, all tailoring the grease to the application. Basically though, to gain in one particular property, you are probably trading away another possibly more useful property. A certainty if the wrong choice is made
Skip silicon, feels slippy to the touch, but is a rubbish lubricant. Buy a can for your door seals, but that's the end of its automotive capability.
The requirement for a wiper mechanism is penetration - think for a moment that most greases have grease gun application in mind or assembly of parts where application is easy.
So an aerosol grease with a solvent to aid penetration which then evaporates leaving a firm grease behind is more appropriate here.
Either a general purpose lithium based one - a specialised industrial type designed to penetrate chains and/or wire rope best of all but hard to obtain - or consider a chain lube as used on motorcycle chains. Find a good product and then use it everywhere - door locks and hinges, brake pedal pivots, handbrake mechanisms, etc, etc, etc. Does wonders for keeping a car feeling 'sweet'.
Waterproof, in this context means it wont readily wash out when exposed to the elements.
edit PS. Re aerosol lithium grease - Wurth and Comma both have which should be readily available from your local auto shop. If there is a Castrol one - take it. There may be others though. Or bike chain lube, but don't be oversold on the anti-wear additive - a decent base oil is more useful. You don't need Moly!
So you think something like this would be better then?
Yep, that's the kind of thing I had in mind. Fine for low duty applications that see neither severe temperatures or loads but where ease of application is an asset. It'll be 4 quid well spent.
Yes of course, didn't make myself too clear! I was referring to the lovely shiny grey lithium grease, I think someone has already referred to the Castrol LM. :D
Me neither! My point was that as there is a 99% chance it is lithium, no point in mentioning the fact. Only when it is different is it worth mentioning.
OK thanks for the input.
Should have mentioned that I have already bough this but can take it back if necesary?
So should I return it and get the Screwfix one or will the difference be negligable?
If you can get the Comma to where it needs to be, it'll be fine.
Application is all!!!
More to the point though. Aerosols make the job a lot easier. Easier jobs get done more frequently. From that, good maintenance practice ensues.. This is a job you will have to do again at some point!
Personally using the same waterproof greese I use on my mountain bike.
