sounds like either a pressure relief valve or aeration going through a hydraulic valve block, both will make a singing / whining noise.
if the symptoms go away when you drain the straight hydraulic fluid (PAS systems etc) and refill with ATF (anti foaming properties) then that's what it is.
it's a sign of a manufacturing or assembly defect, can be non progressive, eg it will do that for the next 20 years, or it can be progressive, and one day it blows a seal in the valve block or something.
all the above of course assume you have clean filters, clean fluid, correct levels, etc.
if your levels are wrong you'll get pump cavitation*** which will do the same thing
the whining is from the hydraulic pump type, gear pumps (eg dowty etc) as used in PAS pumps etc deliver a lot of small pulses of oil, and the frequency rises with pump rpm.
in a pukka hydraulic system this isn't desirable, so you fit a damper which is basically pressure chamber filled with nitrogen which the oil uses as an expansion chamber.. bye bye whine and pulsing.
*** you do NOT want pump cavitation, you are literally listening to your pump being slowly eroded.
