JethroUK
Why does computer stop at 40 mpg?????
markjay said:Mine doesn't... ?
Instantaneous readout on my C220 does, and I've often wondered why, as the 'from start' or 'from reset' figure is often in the 50s or 60s of mpg.
Good point, one to you!JethroUK said:Youve often wondered but not found out? Had mine a day and ill find out in 2 days Hoping someone on MB "technical" forum will *know* why
renault12ts said:Seriously people...RTFM.
And some questions asked are quite funnyjohns E350 said:Why would we want to do that when some people on this forum might like to answer questions asked. Not much point to a forum when the replies are RTFM
geraldrobins said:Likewise why don't the mpg readouts graduate in 0.1 mpg rather steps, 45.6,46.3,47.1,47.9 etc. Other manufacturers can do it.
OK, taking your advice, I've spent the last 15 minutes looking through the FM, and can see no mention of the instantaneous readout, except what it is and how to access it. But I knew this already. Even the illustration shows it max'ing at 40mpg.
What have I missed?
The dashboard display only reads to 40mpg on most models because that is what was decided on by MB, however the actual calculation can be any figure.
The display in Comand goes up to 50mpg.
Did you notice that in the FM?
Renault, Just like in the 80s then?
The newer versions of firmware go higher than 40. You may need to upgrade the firmware.
