Why does my DSF tyre keep losing air?!
bobby
London, UK
1999 C43 AMG
My DSF tyre has recently been behaving strangely!
Normally I run 35psi at the rears and 33psi at the front.
However after a couple of days I will check the DSF tyre and it will be 19psi?!
Anyone got any ideas? Is it a slow puncture>Why doesn't it lose more than 19psi?:confused:
give it time and it will lose more pressure
however, one possible cause (please tell me if im wrong as this is a guess) if its just one wheel doing it, it could be mis-shaped or a small crack in it, and when it deflates to 19psi it fills the loose area up.
Then again i could be talking out my ass
Hello wifes b class tyre monitor kept going off as one tyre doing exactly the same 33 to around 19psi over a few weeks.
Anyway while I was having my new wheels fitted by a mobile tyre man I asked him to have a look. It was the seal round the tyre part of the inside of the alloy was slightly corroded. Rub down with wire brush new tyre sealant on and refitted = fixed :)
It could be the way that the tyre sits on the rim as per Gunnings' post. I have had one or two tyres in the past that have been perfect after the tyre fitter has reset them on the rim.
