anna
- Jan 15, 2008
I also think you are over reacting somewhat.
If at some point in the past the headlamp got water in it via a jetwash or something then that water will remain in a sealed headlamp for many months causing the symptoms you describe.
Open up the headlamp, fully dry it by leaving the car in the sun for a day or get a hairdryer on it and once sealed up again you'll get no more condensation.
Unless headlamp the seal is actually broken (which apparently its not), then its just one of those things that can happen at times during car ownership which is easilly rectified in less time than its taken for you to write these letters.
This is really the attitude of MB which upsets me. Nobody offered to do anything at MB even though the car stayed there for overnight. In the morning nobody suggested me to do anything about the headlight.
check this out first:
1. 6 months ago at the same MB service centre while changing my GSM antenna a guy at the MB shop scratched the base of the antenna. I had to argue with MB to make them change it.
2. The manager at the MB named in the letter at the beginning of this post was rude and arrogant to me when I brought my car for service B.
3. I was not given a replacement car even though I was entitled to have it as they decided to leave me car overnight.
4. Now this story with a headlight....
Am I really over reacting or the service is that bad????
