shazAMG
Not sure where to post this, but both my windows (CLK w208) shudder when they go up? I take it they need lubricating but where and how?
paul m said:Try spraying silicone spray with the window down, inside the rubber window guides then operate windows up and down, plenty spray will prob sort it.
shazAMG said:silicone spray, I take it thats not wd40? wont the window be constantly dirty? thanks
You can take the door cards off in literally 5 minutes. It's about 4 screws and a bunch of clips.Rose Chap said:How easy is it to remove the door card from a W208? I wouldn't mind slightly beefier front speakers but have been scared off that plan by the fact it would mean taking off the door cards.
Obviously if I went to the trouble of pulling off the door cards to fit speakers I'd give the window mechanism a good old clean too.
............that are pennies from the stealer when you break themShude said:and a bunch of clips.
I pleaded poverty and got some for free, I took the dead ones in as evidenceGRAV888 said:............that are pennies from the stealer when you break them![]()
