iveco
- Aug 3, 2017
- SLK 200 R171
yes both flash 3 times and alarm is working
2006What year is the R171?
Dec
Dec
No, it suggest the car thinks the door or bonett is closed, that assumes the car alarm is in full working order.
Dec
My own W202 and I know a W211 will flash 2 times if bonnet is open, maby things are diffrent with a R171.yes both flash 3 times and alarm is working
I've not had much experience with wipers apart from greasing the w202 once a year and the rear on a golf that had been corroded but would it be possible to bench test the motor ?
Disconnect (unplug) the wiper motor, get a couple of loose bit of wire, find which pin are the live and neg from google and just touch them to the battery again being careful make sure it's live to live and neg to neg. If the motor spring to life i suppose the next stop be the SAM connections or a relay BUT if it doesn't i'd just replace the motor as like Dec has stated by forcing the wipers down you've broken inside.
Personally i'd only open it up if i couldn't get one quickly.
Is there a relay relating to wipers ?
Thanks its position 3 not 4 there is no 4 .... the fuse chart says windscreen wipers fuse 33 42 46 washer pump electronic
I would be encouraged by that. Assuming all fuses are tested good? Then it does rather suggest that the motor, motor clutch or, linkage is the failure.
Never having seen this particular set up before!! Pay very close attention to the motor for any plastic pins (snapped) and lying inside the covers. Mercedes do like using plastics that are sometimes designed to fail as sacrificial low cost parts to protect the bigger more expensive part?
That’s a front SAM above, see this link for more pictures… https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=r171+front+sam&_sacat=0
The wipers have 2 relays, usually Yellow, you can hear and feel them click when the are energised. You could try swapping theme around to see if that makes any difference.
You can fool the car into thinking the bonnet is shut if you close the bonnet lock by pushing down on its mechanism with a screwdriver so as to simulate the “square” bonnet catch hitting the lock.
To release the bonnet lock before you shut the bonnet, just pull the Red bonnet release handle in cabin.
Dec
Dec
