02 C220cdi estate no drivers seat electrics
mrfwonderful200
The wifes C220cdi estate 2002 avantgarde has no electric seat movement at all, its not the memory type, the switches are down the side of the seat. I havent checked fuses cos i dont know which one covers the seat! can anyone help?
The fuse boxes (front & rear) have no markings to indicate which fuse is which and I dont want to pull a fuse that will upset something like the stereo code or engine management settings!
I have had this problem. Odds on its a wiring fault in the seat causing a short circuit and hence a blown fuse. A common fault in early C class models. The wiring is incorrectly routed over the seat frame, as a result the insulation wears and eventually a short is produced. The seat fuse is in the rear fusebox in the boot, I can't remember which one. You should have a piece of paper in the cabin fusebox which says what all of the fuses are.
The problem is a relatively simple one to fix, the back needs to be taken off the seat and the wiring repaired and re-routed. Should take your dealer no more than one hour.
Got it sorted, 2nd fuse down from the top in the boot fuse box, a 30A fuse. If it blows again I'll check the wiring in the seat!
hi sorry to jump on ur thread matey but does anyone have a diagram fusebox like u said there is no markings so u dont know wot fuse is for where?
this any good?
bugger. photobucket has downsized them so you cant read the text
Any tips on how to remove back of seat??
Does anyone have any pointers on how to remove the back of the seat and locate the broken wire?
I have the exact same problem as discussed in this thread and would really like to give it a shot myself...
/Johan
