17's Amg Aero 2, 225 45 17, lowered 40mm with eibach pro kit on 95 w124 coupe?
Should be , it's pretty much the same setup i have on mine ....
17" AMG II's , 40mm drop using Brabus Bilstein shocks ...
cool well the kit said 40 front 35 rear, any more pics of your?
Thanks man, looking forward to fitting the wheels now
howard the tire is close to the arches!have you experienced rubbing issues?
Should be fine
Will i be ok with this set up?? Please Help. Thank You!
I've got a similar set up on a 1994 E320 coupe; AMG alloys on 215/45ZR17 - front and 245/40ZR17 rear, no issue with rubbing or bottoming out.
As long as the offset is no lower than 35 you should be fine. An offset of 30 might work on the rear but you can get rubbing with et30.
the problem with 225 is that the car risks to trameline
