2.3-16v Spec
Just to add to Wills comprehensive listing. 2.3 -16v only available as manual. later 2.5-16 manual or auto. colours available I think
almandine red and smoke silver (yellowish tint) brilliant silver,and black they all had 4 sports type seats (only 2 individual seats in back) black leather or black/blackcheck cloth.
Spec sheet from MB ON 2.5-16V as follows
Engine
Four cylinder injection engine, 2.5 litres; output 145 kW/194
DIN/hp at 6200/min. Light alloy cylinder head with twin overhead
camshafts and 16 valves. Mechanical/electronic fuel injection with
fuel cut-off on overrun. Microprocessor-controlled ignition system.
Single, poly V-belt with automatic tensioner.
Transmission/clutch
Five-speed close ratio manual gearbox with direct fifth gear.
Floor-mounted gearshift; synchronised reverse gear,
self-adjusting single dry-plate clutch. Optional extra:
Mercedes-Benz 4-speed automatic transmission. Also available
withtempomat (cruise control).
Suspension
Shock-absorber strut independent front suspension with
broad-based wishbones and anti-dive control; negative offset
steering, multi-link independent rear suspension with five links per
wheel, anti-dive and anti-squat control. Electronically-controlled
automatic locking differential (ASD); hydropneumatic self-
levelling rear suspension. Two coil springs, anti-roll bars and
gas-filled shock absorbers front and rear.
Brakes
Dual-circuit power-assisted braking system; internally-ventilated
floating caliper disc brakes at front, fixed caliper disc brakes at
rear; vacuum brake booster; lever-type parking brake,
Brake-failure warning light for both circuits; brake-pad wear
indicator. ABS-anti-lock braking system.
Steering
Power-assisted steering; steering damper, large padded steering
wheel boss; impact absorber under the padded boss; collapsible
steering column.
Wheels
Light-alloy wheels, 205/55 ZR 15 tyres.
Bodywork
All-steel self-stabilising bodyshell; rigid, torsion-resistant
passenger compartment (safety cell); fuel tank between rear
seats and luggage compartment; impact-absorbing front and rear
sections; excellent all-round vision; four doors; flexible bumpers
front and rear in fibreglass-reinforced plastic. Aprons, side skirts
and the spoiler on the tail underline the sporty character of the car,
improve handling safety and reduce drag and front and rear axle
lift; drag coefficient = 0.32. Electric tilting/sliding sunroof with
built-in air deflector.
Seats
Anatomically-contoured sports-car seats front and rear; seat
springing adjusted to vehicle suspension and seat position; front
seats firmly anchored, adjustable forwards and backwards as well
as for backrest and seat cushion angles; seats adjustable for
height; fully reclining front seats. Inertia-reel three-point safety
belts with tensioners and height-adjustment; safety head
restraints on front and rear seats. Two single rear seats with
folding centre armrest and 2 inertia-reel three-point safety belts.
Fabric upholstery (centre section in check-patterned fabric, sides
in leather), black leather seating optionally available.
Heating and ventilation
Continuous, draught-free flow of warm or cool air with booster fan
forwindscreen, side windows and front and rear footwells.
Quantity and distribution of warm or cool air fully adjustable.
Separate heating control for right and left sides of car. Two vents
for fresh air in the centre of the dashboard, fully adjustable.
Optional extra: air-conditioning.
Windows
Tinted panoramic safety glass all round with laminated
windscreen, electrically operated windscreen washer unit with two
heated dual nozzles. Central panoramic windscreen wiper with
eccentric sweep, two speeds and intermittent control, operated by
the combination switch on the steering column. Heated rear
window. Electrically operated windows.
Lighting system
Rectangular broad beam halogen headlights with side lights,
incorporating a dim dip device, with high beams and asymmetrical
low beams, foglights, sidelights; buzzer warning if headlamps or
sidelights left switched on; pneumatic headlamp range
adjustment for laden or unladen car; parking light; rear lights;
reversing lights; rearfoglamp; illuminated number plate; boot light;
variable instrument illumination; passenger compartment light
with delay-switch controlled by door contact and hand switch,
integral reading light with separate switch; illuminated ashtray,
glove compartment and heating and ventilation controls.
Headlamp wash/wipe units.
Signalling system
Headlight flasher; self-cancelling indicators plus side repeaters
with fingertip contact for overtaking, operated by the combination
switch on the steering column; horn; brake lights; hazard warning
lights.
Locks
Two key multi-point central locking system. Master key for doors,
steering wheel lock, luggage compartment and fuel tank locks;
second key for doors and steering wheel lock only. Wedge-pin
locks on all doors; child-proof locks on the rear doors; luggage
compartment lock; steering wheel lock combined with ignition
lock, starter and starter non-repeat lock.
Instruments
Instrument panel padded, yields on impact. Speedometer; rev
counter/quartz clock; oil pressure gauge; fuel gauge; coolant
temperature gauge; fuel consumption trend indicator; indicator
lights for brakes, battery charge, direction indicators, high beam
and fuel reserve; brake pad wear indicator; milometer and trip
recorder. Warning lights for engine oil, coolant and screen-wash
fluid levels. Centre console with analogue voltmeter, analogue
engine oil temperature gauge and digital stop watch.
Miscellaneous
Leather-covered steering wheel and gear lever. Oddments tray
between the front seats; pockets on front doors; lockable
glove-compartment; panoramic rear-view mirror adjustable to
anti-dazzle position; two heated exterior mirrors both adjustable
from inside the car, electrically operated on passenger side;
padded sun visors with vanity mirror on passenger side; grab
handles on roof frame; clothes hooks on rear grab handles;
padded armrests on doors with grab handles; cigar-lighter;
ashtrays front and rear; velour carpeting throughout; towing lugs
front and rear; warning triangle; first-aid kit in the parcel shelf.
