190e W201 New Injector Problem
zippy500
190E 1.8 Manual
I have replaced the fuel injectors on my 190e 1.8.
Fitting went fine....
When I attempt to start the car now the engine fires runs for about 1 second then dies, does this everytime, tried it about 12 times-same.
Is it possible that I have the wrong injectors for my car?
Eurocar said these where the correct ones..
http://www.eurocarparts.com/search/431220070/p/home
Any ideas,,,Will probably put back the old injectors next weekend if I cant resolve>
Have you fitted the seals around the injectors properly? Also have you checked if they are spraying fuel?
What was wrong with the original ones?
