Problem started when I noticed the radio got servere interference when side/lights were switched on. Found offside rear side light was out, but not registering on the bulb out warning light. Changed bulbs (the torpedo shaped ones in aclamp connector) but no joy.
Have checked bulbs - OK
Checked voltage across connector with bulb out =12.4 Volts
Radio interference disappears if bulb is removed with sidelights on and returns when replaced
Any suggestion gratefully received.
