paddy@polyposta
comp in leeds but is proper part for 9 blade fan and matches part number given on that website linkDid you get this part from a Mercedes Dealer?
Dave!
Dave!
Rather than cut the bolt down I'd be inclined to add a washer as a spacer, in case the viscous pulley isn't the correct one.
Thanks but have already cut it now
see how I go
I can't remember, I just did it 1 litre at a time as I mixed it. Be sure to have your heater on full in the cabin. 50/ 50 mix.
Dave!
Shamelessly stolen from K6JRFs page.
http://pages.prodigy.net/jforgione/CTS_Mod.jpg
Take off the plastic cover infront of your airbox (The large oblong one) and you will see the sensor.
Be careful removing it though as they can be tight.
Dave!
Apparently if you have to tap the 2 x aux fans for them to come on then theres a problem with the bushes in the fans...can anyone confirm this?
Good news, after changing viscose coupling and coolant, all seems ok. have just driven to Leeds and then back again 5 hours later (140 miles round trip approx) and all seems ok. Gauge was hitting 80-90 on the motorway. When I arrived at Leeds I let her tick over for a while and temp went no higher than 100!.....looks like that has solved that issue and yes car is noisier.
I have also ordered a cooling harness from Jim Forgione
Just need to sort those 2 x aux fans now!
By the way the Air Con does not work, gas is out and it needs specking to the new gas. The fans wouldnt be effected because theres not enough gas in the system to operate the air con would it, I shouldnt think so, but thats another job I need to get done, obvioulsy the old/original system ran on R12
Did take the car in to a local compnay and they said just a valve or two........any comments/advice would be appreciatted
and thanks everybody for all the advice so far
Paddy
