masherbike
- Jun 15, 2017
- GL
I have a 2011 GL 7sp 3.0 diesel. It has just done 40,000 miles. I get a shudder from the torque converter when it is hot and stopped in Drive, it goes when it starts to move. I realise it is due a fluid change now so I have been phoning round. One independent quotes £225 but don't drain the torque converter. I suspect the judder is in the torque converter clutch due to the degradation of the fluid. The independent said they ''never drain the TC and neither do the main dealers''. If the problem is due to the old fluid in the TC I should insist they drain it right? Is the TC sealed or does the gearbox fluid find it's way in? Any help will be much appreciated.
