86 w124 - hose from air filter housing
paul_jw
i meant to add this to my previous thread, but realised i couldnt change its title, so apologies for two threads.
i had oil all over my rocker cover and head, thinking this was an oil leak i thought the rocker cover was at fault. however upon inspection of the inside of the air filter housing it had a load of oil in it.
this seems to be coming from the rocker breather, where it comes up into the filter housing and back out through a small 3-4mm hose. there was a hole in the side of the filter housing for a small hose, which was missing and i have replaced it - however where does the other end connect to? i realise usually they just recirculate into the inlet or a catch tank but i cant find anything missing or off.
thanks for any replies in advance :D
paul.
