MarekW
My car 2007 GL320CDI
I just replaced my ac compressor, expansion valve and the receiver/drier due to not
cooling low pressure was at 60-70 psi and high pressure was at about 125.
The new compressor is SSB (chinese version of Sanden/Behr C011280C, Perfect fit)
All is connected and charged with proper amount of 134a freon (vacuumed system 1.35
min to -30 and holding vacuum after 14 hrs), but the only way the compressor will
start is with DAS diagnostics under actuations of ac compressor.
Once it is runing it gives low pressure of 45psi and high pressure of 205psi, ambient
temperature 33.5c (92.3f).I am attaching some pictures for you to view.
The compressor will not start with the push button on AAC.
I am wondering if it is the compressor problem or something with my car ( I did not
have any of this issues with original compressor error code 9006)
Please help
Thanks in advance
Please help
Thanks in advance
