miro
If you are referring to my comment about a single exchanger, I meant how could a problem in the mono valve make one side hot? Perhaps after all the same as the claim on the refrigerant, which I did not understand either.
The flap issues as referred previously would sound absolutely logical but the reset at least did not seem to help on this car.
The evaporator always makes some "hissing noise" as its job is to evaporate the liquid from the compressor but I assume this time the noise is significantly stronger than normal. Could low refrigerant also increase the noise?
I would assume a hissing noise from a leak being quite short in time, if it was leaking so much that one could hear it, it should not have 134a for too long time then, would it?
The heater element and cooler element in the W203 crosses both sides. There is a divide in the middle of the assembly with flaps for the left and flaps for the right.
