sawman
I think I have a bit of a bearing issue, so picked up some new ones on the way home, looking at the hubs there ia lot of crud around the caliper bolts, It looks like these are 18mm bolts (I know this because I have 17mm and 19mm wrenches) so after obtaining the correct size in the morning I am hoping to get these off and then get the bearings swapped.
Is there any risk that the bolts will have cold welded themselves in and that they will fracture rather than come out - I have given then a few squirts of penetrating fluid this evening - so hopefully I'll stand a chance tomorrow
tips gratefully received
