The early idler gears teeth wear out. As there is no balance shaft on the m273 and it is literally a timing chain idler gear. Why can't this simply be done in situ? Remove the cam covers, remove the the timing chain case cover, undo the tensioner, would this not leave enough room to be able to slide the gear off and slide the new one on?
