vincentsemper
- Dec 2, 2006
Hi all,
i have retrofitted my ML (june 2002) with a Comand2 and sent my previous aps30 to a friend of mine to mount on and old E class (i think w210).
The E class was previously equipped with an audio10 system and my friend plugged the unit without trouble to the connectors but.......
The navigation is not working !!
He receive up to 8 satellite but the position is wrong and not updated.
Is someone so kind to give me the magic solution ?
The second question is related to my ML retrofitted Comand2.
As i wrote in a previous post, i have not the w163 comand but a w210 and i'm using a can bus simulator. The question is: the previous C plug was inserted in the APS30 where i have discovered (thaks to this board) there is the CAN High and CAN Low connection so perhaps using this cables (available in the ML, previously used and not now with the comand) i can connect the A1 (gal) and the CANs coming from that connector avoiding the simulator ?
Again thanks in advance to Alfie and the others experts of the board.
Vincent
Vincent
