Wet clutches.
Low friction additives in many car engine oils make them slip badly, hence the recommendation against using them in Motorbikes where the same oil lubricates both engine and transmission, (including the clutch).
Pan
(Owns BMW K75 & Yamaha RD350 bikes as well as the new C200k & a Disco)
These 20,000 mile oil service intervals suck. use oil half the price, use reputable filters and change twice as often. thats my advice anyway. I change my oil usually at 5000 miles, use Comma or unipart oil or equivalent. The only reason some oils are going on for 40-50 quid for 5 litres is that they are expected to cool,protect and lubricate for far far longer than is right.
I change my oil and filter for less than £20. most of my cars have and have had 150,000 miles plus on them,a few 250,000 plus. Never had a problem.
Just to add i was in Morrisons Stewartfield,East Kilbride and noticed that they are selling Merc spec Castrol Magnatec at £14.99 for 4 litres this sounds like a bargin is it?
merc spec 229.1????
.. in the CLK it gets dropped every 3000 - 5000
If you look at the oil analysis threads in on US forums, where they take this stuff very seriously, wear increases with new oil, settles down at 3-5K miles and then starts to increase again at 10-12K.
Call me thick if you like but how can wear increase with new oil ?
I don't know, and the oil analysis threads tend to deteriorate into massive slanging matches!
Amongst the suggestions are that it could be due to starting the engine with no oil pressure after the oil change, the new oil picking stuff up that the old oil left behind due to increased detergent action and (most unbelievably, but who knows?) that the additive package isn't fully activated.
One intersting thing is that when they (ie Americans) run their oil for extended periods they usually change the oil filter at the mid-point. MB say for extended drain a fleece oil filter should be used but they're never used in the UK.
If I run the oil in my SLK for about 3K miles, do you think I could sell it for more than I paid for it in the first place?If you look at the oil analysis threads in on US forums, where they take this stuff very seriously, wear increases with new oil, settles down at 3-5K miles and then starts to increase again at 10-12K.
There is no obvious answer to the question. So the next bit is pure speculation.
As an engine oil is expected to turn acidic in service due to contamination by the byproducts of combustion, the oil initially is supplied as slightly alkaline. Alkaline being corrosive (think caustic), I wonder if that accelerates wear.
As said earlier, pure speculation. But if increased wear with new oil is fact, there will be a reason.
RH
Thanks for the various replies folks. So it would not be a good idea then to change the oil shortly before laying up the car for a long period (i.e. my 190 will be laid up for the winter so I shouldn't change the oil beforhand ?)
What I would suggest you don't want to do is to leave oil in that might have traces of condensation which can turn acidic. So if the car has been well run (ie not lots of short journeys) then I would leave it.
Otherwise change it shortly, but not immediately, before storing the car.
That's kind of what I was thinking. Avoid the initial alkilinity, but not so far as its turned acidic.
TAN and TBN numbers indicate the alkilinity/acidity balance, so if you really wanted to be scrupulous, oil analysis would give the answer. Assuming of course that initial alkilinity is indeed a problem!
The suggestion from Rory I reckon covers it.
Incidentally, the old habit of using discarded 'bursting' oil as a corrosion preventative/underseal is pretty laughable. But still practiced by some!
Any other suggestions as to why an engine might wear more immediately after an oil change?
While this type of speculation is interesting it is ultimately futile unless anyone can suggest how you can avoid introducing "nasty" new engine oil into an engine while changing it's oil.
While this type of speculation is interesting it is ultimately futile unless anyone can suggest how you can avoid introducing "nasty" new engine oil into an engine while changing it's oil. Taking the arguement further will then degenerate into a chicken and egg debate a question which evidently some protein biochemists have recently solved---- NOT!
Chicken or the egg - Wikipedia, the free encyclopedia
I believe that becoming a Buddhist helps with this sort of thing !
Hooooooooooooooooooooooooooooooommmmmmmmmmmmmm!!!!!!!!!!!!!!!!!!!!!
You can decide how often you want to introduce new oil.
Hardly futile if it avoids an engine being left over a prolonged period with corrosives in its internals.
