Carrsey
Anyone got any experience with these MERCEDES DIPSTICK E CLASS S CLASS CLK VITO C CLASS JAGUAR | eBay
I dont have experience with that actual one..
There is no reason that you couldnt use it as long as you are aware of the "official" measurements of the full Hot & Cold marks..
That price is very good indeed.. I got a so called official MB Tool which was 15 times that price !!!
The measurements you need are indicated on the photo below (Taken from my "Official Tool" as it were.
Mine is longer than the dipstick tube and works by bottoming inside the box, not on the outside of the tube as regular dipsticks do. For mine at least the second pic posted by sspeed is not applicable.
Yeah it says in the ad, it just pushes in until it bottoms out..
The genuine mb dipsticks are the same, push in untill it bottoms out.
Dipstick is longer than tube so that it can be used on all models with varying lengths of dipstick tube
Yeah enquired with MB and they said it was 40 odd quid. Think i will get one off ebay and see. I aasume the upper mark (80) is the normal full operating temp..
Here's the thing...the genuine one does NOT bottom out...the little diamond shape above the top measurement stops it bottoming out.
So, when using a home made one or the Ebay one make sure to be aware of this and subtract (or is it add) 1 cm to the measurements you get to be correct.
What about it you sprayed the end white so the oil showed better.
Man, if we could somehow have this nailed once and for all! I've read discussions on other forums about this and not many people agree with this. People show pictures of transmissions with the pans dropped and the dipstick sticking out freely.
1cm out would be damaging (low or high). Has anyone actually tested this with the pan down?
