tamrsoft
If it looks like yours then it must be the same type of unit. I will check the fuse box tonight, puzzled why your fuse 17 should have been taken out, maybe previous owner wanted it permanently disabled.
fuzzer said:its a great wee gadget , my engine is over 40 degrees in 4 min on -2 and -3 mornings.
Dunhamkid said:Do you notice any difference in fuel consumption using the heater?
tamrsoft said:Puzzled as to how it can run the A/C compressor in reverse without the engine running backwards.
I have checked out the piccies on the MB WIS CD Manual for 'Auxiliary Heater ' and the unit shown is definitely diesel driven and very different to the pictures shown of my unit so as Dunhamkid states, mine must be electric.
Comment for Dunhamkid - my fuse 17 (indicated for Auxiliary Heater) was also removed but I did notice that the fuse position did not have any contacts in it so it would serve no purpose putting a fuse in that position anyway. I have a feeling that the device that we have is not called an Auxiliary Heater but something else, but what ? What amazes me most is that the last people to know or understand are the MB Service Dept.
fuzzer said:I can hear a difference in the engine tone when its cold with the heater on
Midland45 said:I think the booster heater system fitted to diesels, is simply an electric heater unit in the coolant system. It can be set in one of the menus to operate if the temp is below 6 deg C. This will allow the engine to reach normal operating temperature more quickly, however the trade off is more drag via the alternator and thus slight drop in mpg. But of course the mpg increases as car reaches normal operating temperature, so its difficult to ascertain the total effect on mpg. It does of course lead to usable warmth in the interior faster though.
Dunhamkid said:Can you elaborate on how you set this unit to operate in one of the menus? I can't find that info in my car manual. The only control appears to be with the switch situated next to the cigarette lighter
I meant reverse function (ie heating rather than cooling) rather than literally running in reverse!tamrsoft said:Puzzled as to how it can run the A/C compressor in reverse without the engine running backwards.
Paul64 said:Many of the A/C units for shops and houses work on the same principle where the compressor runs normally but valving in the gas lines change the direction of the gas so it runs to the evap first rather than the condenser which, being in the air ducting, heats up as soon as the compressor turns.
Maybe it's not like this at all however, it's a great idea anyway!
tamrsoft said:This is a photo of the unit in my car, can anyone confirm whether this is an electric or diesel powered unit.
