B180 CDI o/side dipped headlight bulb changing .
baztheblade
MB B180
Hi everyone, as anyone tried changing the off/side dipped headlight bulb from the b180, if so could you give me any tips on how to remove the spring clip which holds the bulb in place, tried for over an hour this afternoon with out any luck. used a mirror to see its location and looks easy to remove but i could not get the clip to budge one way or the other. any help would much appreciated, thanks baz.:confused:
Thanks grumpy,had a look at the link and the only thing i did not do was trying to shove on the spring clip in a side ways motion. will give it a try tomorrow.
Just to let you know Grumpy, it worked a treat (took a couple of minutes) thanks.:)
