Thanks very much for that info.A6519060026 for non start-stop, Denso
I believe the Fiamm vr800 is an AGM battery. Get an exchange reconditioned starter motor
Whilst I agree, we are assuming the correct jump start technique was used. Just connecting a ‘donor’ battery is often not enough, the engine has to be running to provide enough ‘oomph’ otherwise you’ll still just get a click.If you have tried to jump start the car with a known good donor battery and it still won't turn over, then it's not the battery at fault. It has to be the starter, it could even be loose battery connections or loose at the starter itself. If possible check for 12v at the large starter terminal, and again whilst a friend tries to start the car.
I think it would be enough if it’s a good battery. 2 batteries in parallel would at least be enough to attempt even a sluggish response.Whilst I agree, we are assuming the correct jump start technique was used. Just connecting a ‘donor’ battery is often not enough, the engine has to be running to provide enough ‘oomph’ otherwise you’ll still just get a click.
But if it’s not a good battery? which is what we are trying to establish.I think it would be enough if it’s a good battery. 2 batteries in parallel would at least be enough to attempt even a sluggish response.
Fair point and I have the car booked in with my indie. Meantime I want to see to see what I can see...While I admire your persistence, I’m wondering why you’re not dropping this in to your friendly neighbourhood car electrician?
It does seem like a straightforward problem for someone “with that very particular set of skills. Skills he has acquired over a very long career. He will look for you, Will find it for you. And he will kill it for you."
(With apologies to Liam Nees
Donor was good but as for getting under the car, not for me unless someday I invest in a car lift.If you have tried to jump start the car with a known good donor battery and it still won't turn over, then it's not the battery at fault. It has to be the starter, it could even be loose battery connections or loose at the starter itself. If possible check for 12v at the large starter terminal, and again whilst a friend tries to start the car.
hi it was done correctly oomph and a little vrrooomWhilst I agree, we are assuming the correct jump start technique was used. Just connecting a ‘donor’ battery is often not enough, the engine has to be running to provide enough ‘oomph’ otherwise you’ll still just get a click.
I didn’t suggest an Indie.Fair point and I have the car booked in with my indie. Meantime I want to see to see what I can see...
My point was that a car Electrician has decades of specialist skills and experience to stop you from wasting time, unnecessarily replacing parts, and making the situation more complicated and worse, as you seem to have done from your last post.
A battery “specialist” will always just sell you a new battery, no matter whether you need it or not. He’ll always sell you a new battery even if the battery is flat, or if you’ve not made good connections. It’s how he feeds his kids.
Finally if you’re about to blow your last big fuse, there’s something wrong with the circuitry that isn’t battery related. Weak batteries don’t blow fuses. And you really should “give in” and buy a bag replacement fuses for less than a fiver from Amazon, rather than risk blowing your last fuse and getting stranded.
