Battery drain
Had a similar experience with battery drain with my 1995 S320. The dealership was unable to find the cause, so I took it home and traced the wiring from the battery in the rear up over the fender on the right. I removed the trim, and pulled the large cable of wires back and forth, which apparently dislodged the faulty wire away from the source of the electrical loss, as the battery drain then ceased. Before that the battery woul drain in about 3 days while sitting.
