- Feb 8, 2007
- Location
- Portsmouth, Hampshire.
- E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
Make sure your car is level. if not, use a jack to level it out.
Thanks buddy.The pipe resting on the wing! Sackable offence in my world.
The engine has to be very hot for it to work properly. Coolant maybe at 80 but the engine oil may still be cool. Take it for a 30 min run to warm it up properly otherwise it will take a very long time to vac the oil out and you will not be evacuating all of the oil either as it will be too thick. Also the oil filter must be completely undone as that holds about 300ML of oil.
I would probably do it again and if you want help with reducing the oil viscosity use an engine flush. A properly hot 642 engine's oil will be extracted in about 4-5 mins.
When filling, put a few litres into the filter hole. The 642 has a tendency to skip teeth on the timing chain after an oil change if the timing chain is worn and the oil filled tensioner is at max.
@OneForTheRoad
Its says 60c max in those bull¢hit instructions
Id factored in the oil temperatureLOL.....C not F.....I think 40.3c is the highest ever UK temp! 60c would be a bit toasty!!
It's been mentioned like 6 times already. To the point of being boring.There's a huge saftey factor built in to products like this.
It's probably been tested to 150°-200°.
So 60° is guaranteed not to cause any problems.
Saftey related, scaffolding towers etc. are tested to x10 the safe working weight.
Don't let D of Cs and C of Cs put you off. The same products on sale to the trade may well have a higher spec.
Joe Public must be protected from himself.
Health and Saftey Bollocks gone mad!
I use 5/30 . This topic is now closed .So are you saying that upping the oil temp to 90 or so will let it flow at about three times or more the claimed max flow rate as said but some posters? Seems unlikely to me.....especially as a typical 10w/40 oil (see chart) at 60 is barely any thicker than at 90c!
Irish Coffee????Would this method work with coffee and biscuits instead of tea
Thats a bit of good solid advice!The pipe resting on the wing! Sackable offence in my world.
25 years working on Mercedes.Thats a bit of good solid advice!
You can't sue them for falling off.How does the safe working weight help when you fall off
