OneForTheRoad
- Apr 20, 2015
- Location
- uk.
- 2019 Glc coupe 350d was 2017 e350 c207 .. +65 ford kuga 2.0 cdi zetec awd..
Above and beyond.Does it have MB Approval?
Sounds like someone else now won’t get their PelaResponse from Amazon marketplace seller. They didn't spot the order, but after I messaged they processed it and it was dispatched yesterday. Pela on it's way
This might be my best Christmas present!![]()
Yeah, maybe.Maybe it was returned or sold on because it is damaged and doesn't hold a vacuum?
There's one black o ring on the top , I pump mine 20 TIMES every few minutes . I also plan the oil change and start it asap following a good run out ,when things are HOTYeah, maybe.
These are pretty simple design and remind me of my homebrew 'beer spheres'.
When I've got more time, I'll check all the sealing surfaces for anything not smooth that could cause an issue. On the beer spheres, it was usually some slightly wayward plastic flash; overspill from the injection molding process. Some careful attention with some wet and dry sorted out typical beer sphere pressure retention issues, where the flash was interfering with the rubber seals or o-rings.
The oil takes a lot longer to get up to temperature than the water.Pela 6000 arrived this afternoon. It was originally listed as 'used, like new', but I thought if it was used (with filthy black oil) how could it ever be returned to 'like new' condition. When it arrived, as suspected, it was brand new and unused. A bargain at £38 delivered.
It was a reasonably warm 2 degrees outside this evening, so what better time to crack on with an oil and filter change and new orange turbo inlet seal.
All went to plan. Well, all except the Pela being very, very slow to extract the oil. Over an hour in the end. Engine was showing a bit over 80 degrees when I started (although it didn't feel that hot under the bonnet), but due to the time it took to syphon the oil, I suspect the temperature had dropped a lot and the viscosity had increased quite a bit by the time I'd finished.
What wasn't in the instructions (or at least, in my hurry to get started I didn't see) but became quickly apparent was that the seals need greasing with a silicone grease otherwise vacuum loss happens very quickly as air passes the seals. I greased up as best I could outside in the dark and it was manageable in the end, but still losing vacuum too quickly. Since finishing for the evening, I've greased all seals on both sides, so hopefully next time it will hold the vacuum longer.
@W1ghty
Any tips for getting it to hold a vacuum for a long time?
Obligatory Pela action shot
Me too , I was thinking of getting a Lidl pump everyone is talking about as a back up to maybe do some other jobs but when I hear it takes 30 minutes to move 7 litres of hot engine oil I probably won't bother.9 litre Sealey works well for me.
I’ve got an electric pump from eBay. Takes about ten minutes to empty the sump (6 litres). Goes straight into an empty container for disposal.Me too , I was thinking of getting a Lidl pump everyone is talking about as a back up to maybe do some other jobs but when I hear it takes 30 minutes to move 7 litres of hot engine oil I probably won't bother.
Don't believe all you read.Me too , I was thinking of getting a Lidl pump everyone is talking about as a back up to maybe do some other jobs but when I hear it takes 30 minutes to move 7 litres of hot engine oil I probably won't bother.
As you found out , lube the seals .Pela 6000 arrived this afternoon. It was originally listed as 'used, like new', but I thought if it was used (with filthy black oil) how could it ever be returned to 'like new' condition. When it arrived, as suspected, it was brand new and unused. A bargain at £38 delivered.
@W1ghty
I've done a few with Stella and at times Guinness.Would this method work with coffee and biscuits instead of tea![]()
That would require a whole new routine built from the ground up and overturning decades of habit , so it’s a hard NO buddyWould this method work with coffee and biscuits instead of tea![]()
I'm surprised its so much faster than the claimed flow rate of 0.2L per minute...which would mean 40mins to get my 8lts out........normally stuff tends to fall short of the claimed performance I find. But that's great if it can do so much better. Instructions below...see flow rate and max running time about half way down in "Technical Specs".Don't believe all you read.
10 or 15 mins at most if hot.
ULTIMATE SPEED HG03271 Oil Pump 12 V Instruction Manual
ULTIMATE SPEED HG03271 Oil Pump 12 V Instruction Manualdevice.report
The pipe resting on the wing! Sackable offence in my world.Pela 6000 arrived this afternoon. It was originally listed as 'used, like new', but I thought if it was used (with filthy black oil) how could it ever be returned to 'like new' condition. When it arrived, as suspected, it was brand new and unused. A bargain at £38 delivered.
@W1ghty
