best W210 lowering springs
Yeah i was the same with the turbines, the more i look at it, the more i like them on there, they were only meant to be on until i found something new, but i might keep them!
Here you go mate (needs a clean this weekend as the wheels are covered in brake dust, and you can see where the bumper needs spraying)
First thing is to check the spring pads. you may be able to get some reduction if you have bigger ones fitted. A pad with one pip is the least with 5 pips if the highest. So if you have 5 pips on your front pads, by changing to 1 pip you can lower by 16 mm:
Front
210 321 0184 5mm
210 321 0284 9mm
210 321 0384 13mm
210 321 0484 17mm
210 321 0585 21mm
Rear
210 325 01 84 5 mm
210 325 02 84 9 mm
210 325 03 84 13 mm
210 325 04 84 17 mm
You can check the pad number by feeling the bumps on the pad itself:
See here: HELP!! TIPS/DIYS: Chassis, Brakes, Exhaust, Steering, Suspension - Benzworld.org - Mercedes-Benz Discussion Forum
Sorry to bring up an old thread, but where can i get the lowest ones from? I've found a couple of european sights, but can i just order them straight from MB or anywhere in the UK?
thanks
Thanks mate, i'll give them a call in the morning!
