230K Do you have any starting issues in the cold weather on 50/50 mix?
I have been running on WVO mixed with 5% unleaded petrol and only recently needed some dinodiesel to help with cold starts on my E300D non turbo W210.
I did have some diesel knock due to a coked injector but its a little better after some injector cleaner.
It runs fine when warm but does need a little more maintenance on veg. More frequent oil changes due to engine oil contamination and regular doses of injector cleaner. A small price to pay since every mile is a smile at 20p/ litre.
What I find confusing is that many people suggest that you can use clean vegetable oil in an unmodified M606 engine. So why pay nearly £500 for a kit with a second fuel tank that ruins your boot space, install lots of pipes and components and switch between DERV and vegetable oil when it appears that you can just pour the vegetable oil into the original tank and turn the key?
I must be missing something. £500. Money for old rope?
Because the cold viscosity is harmful to the injection pump, cold VO does not burn completely and cold VO will coke the injectors.
Yes it does. The engine runs on normal diesel until the VO is at least 160*f, then you switch over to VO and use it all you want. You switch back to diesel for a mile or so to purge the injection system with Diesel when you are about to stop the engine for more than a few hours.
A two tank system is the only way to do it. Single tank "conversions" are little more than a filter and should be avoided.
Make sure it is legal for you to use VO in the first place. I know for a fact it is illegal to use in the USA.
It is legal in the UK - surely you realise this is a UK-based forum?
In the UK, you pay no tax on biodiesel unless you do more than 25,000 miles per year. The category "biodiesel", includes new vegetable oil and recycled waste vegetable oil that has been used for cooking.
My understanding is that you should put up to 80% veg oil or cleaned chip fat and 20% unleaded fuel to thin. This also prevents leaks in the system so I am advised.
