Red C220
Hello all,
I today collected my new 2011 C220 CDI Sport Estate in Fire Opal - hence my moniker. Standard Audio 20 - not COMAND.
Already I've stumbled upon my first user problem.
This is a downsize from an ML300 Sport which was traded (and a new A class for the last 5 days as a courtesy car whilst the new one was delivered).
I have a Motorola Gleam phone (yes I know - it has big buttons and makes phone calls - that's all I need!) and have had no issues connecting it in either the ML or the A class but I'm struggling with the C Class as follows:-
It pairs as you would normally expect, except the new Audio 20 has a new version of Bluetooth (2.1) which connects through Secure Simple Pairing.
Basically instead of typing a four digit code on the Audio 20 then repeating the same on your phone, the system automatically generates a 6 digit code and sends it to the phone - it asks you if the numbers on the phone and the audio 20 display are the same - if it is you press yes you're done.
All nice and easy.
It then asks me for remote access to the phone book on the handset - which I answer yes (I assume I'm meant to say yes - this is new to me?)
So far so good.
However, I have no audio.
The Audio 20 recieves and makes calls in the normal manner, there's just no sound through the system whatsoever.
I checked the mike wasn't switched off, I checked every setting I could on the phone, I de authorised and re authorised...still nothing.
Hmm - I'm thinking the car is duff....so I go and find Mrs Red C220's phone - it pairs in the normal way (4 digit code) - works perfectly - sound intact....
Try my phone again - no audio at all - still makes and receives calls, you just can't hear a sausage.
Right I think, I'll force the new phone through on the old four digit code entry and all will be well - you can't it's all automatic.
Now I'm convinced I've just got a wrong setting somewhere but I'll be damned if I can find it.
Do any of you technological people have the answer for me?
All nice and easy.
So far so good.
