mike_es
Morning!
Was working on the wife's slk yesterday as it had the usual c/l problems.
Sorted the drivers door, it had broken on the knuckle and bodged by creating a tube out of gaffer tape???
So with the help of narrow pipe (from a wd40 spray can) and some plastic heatshrink tubes job done.
However, when I went to check the boot, there is a small white reservoir on the mechanism which creates the pressure to move the rocker arm for locking and unlocking, which was/ is hissing. I've tried lubing the seal, creating a better seal around the outside, but it is leaking air where the piston enters.
Is there a fix for this, a replacement part I can get or am I stuck with a manual boot?
Any help would be appreciated.
