Brake disc sizes
flango
Hardcore MB Enthusiast
Gods own country
Mercedes SLK R171
Does anyone know if the W202 C230k and the W208 CLK230k use the same front and rear brake discs as each other? I know the CLK 320 and 430 are different as they are larger. Just been offered a set of Brembo discs and pads seriously cheap but they are for the w202 C230k seller tells me they will fit my CLKand he is reputable but no mechanic. I'm pretty sure the fronts on mine are 288mm but no idea about the rears
They the ones in Wales ?
C230k
Fitting Position: Rear Axle
Brake Disc Type: Full
Diameter [mm]: 278,0
Brake Disc Thickness [mm]: 9,0
Minimum Thickness [mm]: 7,3
Height [mm]: 53,5
Hole Arrangement/Number: 05/07
P/n
124 423 04 12
124 423 05 12
210 423 04 12
210 423 09 12
Fitting Position: Front Axle
Brake Disc Type: Internally Vented
Diameter [mm]: 288,0
Brake Disc Thickness [mm]: 25,0
Minimum Thickness [mm]: 22,4
Height [mm]: 46,5
Hole Arrangement/Number: 05/06
p/n
210 421 07 12
The rears for a CLK with VIN 208.347 are A2104230412 ,so are the same.
