- Jan 21, 2005
- Location
- Mittel England
- Smart ForFour AMG Black Series Night Edition Premium Plus 125 Powered by Brabus
I have a 2003 53 ML270CDi. The brake wear indicator is glowing on the dash when braking sometimes, so it's time to take action. Don't fancy the quote from the MB dealer, so I plan to have a go myself.
Pricing up the pads from various sources, and my local motor factor said that they have two different shaped pads listed for my car, and both state suitable for a 303mm disk. Forgive the awful descriptions that follow...
(1) Square-ish shape secured by two pins.
(2) W-shape-ish secured by a spring clip.
Any idea which is likely to be correct?
Also anyone know if you can re-use the wear sensor in the replacement pad, or whether you have to buy new sensors?
Finally any tips gratefully received:
>> links to how-to guides;
>> suggestions for pads to avoid notorious ML squeal; and
>> suggestions on suppliers in UK.
Many thanks in anticipation!!
