Ok its definitley not the MAF or MAP sensors i got a now Ait Flow Meter (Bosch) fitted it and still having the issue
I hooked it back up to the DAS and there was a new code i dont know if that is a result of me changing the Air FLow unit which was
2355-002 Check system exhaustgas recirculationcontrol-the air mass cannot be regulated.The air mass is too large
never seen this one before the old one still there but the symptoms of the fault have not changed at all.
I did some more tests on the car while i was plugged in i dont know if they mean anything to anyone;
Y27/9 Left ERG test
position 5.0%
Compression test all came in around 280-290ish
I did the Y100/1 Ricght charge pressure positioner what i didnt get there were three options but they all give the same values the three were
1)nothing selected
2)the on/off ratio is set 10% after which the boost pressure drops
2)the on/off ratio is set 90% after which the boost pressure rises
no matter what was selected the enigne was 1400 and boost pressure 1007
is it time to take it in somewhere? i really love the car but not looking forwards to potentially a massive repair bill so hoping someone can piece all this together with an answer
Y27/9 Left ERG test
position 5.0%
1)nothing selected
