glynandrews
- Jan 12, 2013
- e220 coupe
Hi Guys,I wonder if anyone could shed some light on this problem as its driving me mad!I have a 1993 ce220.The tick over is too slow and as its a bosch system has no means of adjustment.I have replaced the air flow meter which ade no difference whatsoever!I have traced through the vacuum pipes and after many hours found that a vacuum pipe is attached to the fuel evaporation system on the n/s inner wing.If i remove the vaccuum pipes and connect together it ticks over almost perfectly.The only problem is that this then seems to cause vacuum issues in the tank resulting in a hiss when the cap is removed.There is a bad smell of fuel in the car which seems to stop once this is done.I have tested the valve on the fuel evaporation system valve which doesnt ever seem to get any voltage?The question is where should the voltage be controlled by,its a new valve too just in case.I have found that if i connect the pipes back to front its almost perfect?Bizarre and doing my head in!!I have bown down the pipes to the tank and all seems clear.Could i run an ignition controlled live to the valve?Much baffled and any info gratefully received.
