Smokin..o0O
- Mar 8, 2005
LastMinute.
I did not realise that site with merc info was well known on here.
I spent the best part of 1 day searching the net and it was a PM on another forum that directed me to the site.
On the main page http://www.detali.ru/cat/oem_mb.asp enter VIN and the model and spec of the car is listed.
Parts 110 and 120 are the 2 units I have been referring to in my posts.
Part 110 A2034703294 AUXILIARYPUMP £116.92
This is the driver side unit which is nothing more than a plastic vessel with inlet and outlet connectors. The fuel pickup hole on this is not visible though.
The description "AUXILIARYPUMP" is very misleading.
Part 120 A2034701341 MOUNTINGPLATE £221.61
This is the passenger side unit. Described as a mounting plate. This unit carries both inlet and outlet fuel line to and from the tank, and also internally to the driver side unit.
Seems just a tad expensive for a "mounting plate"
I am in the process of removing both these units right now. If I am successful, I will take some pictures and hopefully post them here for you to see.
There are no pumps of any kind that I can see inside this tank. The only electrical connections entering the tank are the wires connected to the sender unit.
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
