Originally posted by pepe
i definately have that wire, but doesnt seem to work with nav. 12v when still and 6v when moving . am i right in thinking the pulse wire should pulse 12v when moving cause this wire is not doing that. have the same year car as jimmy and shude but my iso connector is the big square block as found on most aftermarket units. koolvin,did you say i could get the signal from the instrument cluster,i may have to try this. thanks for your patience guys. ps can anyone tell me what theyre green/purple reads with a voltmeter if known just so i can definately rule that out. thanks
