Just a quick question to any of you, have you heard of problems with faulty fuel senders on the c250? I was messing with the car last weekend and it ran out of fuel, yet the gauge was showing quarter tank. Is this a common fault?
1/4 fuel shortage is usually down to a blocked fuel strainer on W124's.... maybe the same on the W202 aswell? or could be something to do with the saddle tanks.
worth checking the strainer and cleaning it or replacing it if you can to eliminate that possible cause.
Hi fella's,
I also have a C250 TD, and experienced a very similar problem/sound when I first got mine around a month ago.
I took it to my mate who has excellent knowledge of diesels, and as dieselman says he said injectors. So along with a hand from him, we took out all 5 injectors and he gave them a new lease of life. Put them back in, the problem/sound after 30-40 seconds of driving had totally disappeared. Excellent result, so I would opt for doing that guys.
Luckily it cost me nothing however (few beers) and all was well. However last week I upgraded my injectors for larger ones (not sure exact spec) but the car has so much more pull, a little more smoke but with a piggyback/map it should sort it out...(not that i'm that fussed, dont mind black clouds ) I can get specs on injectors if you lads are interested...
As well last night, I took the cats out...to say the least, a BIG difference!!
Cheers,
Mark.
Hi fella's,
Cheers,
Mark.
I have used the Diesel Purge and it quietened it down alot, its still there faintly but no where near as bad, was very smooth when running on the purge but when put back on diesel, noise started again but not as bad.
Any news on the bigger injectors? As I think i'll still get mine reconditioned in due course.
I'm getting quoted about £300 quid, for getting my injectors reconditioned!
Check the engine's compressions.
