Hi, I seem to be having the same problem. Same car, but a 97' high milage.
Recently changed the plugs, the battery is fine.
Initially, after changing the plugs everything was fine, but a week or so on and the car has trouble starting from cold. usually about 3 or 4 times cranking at about 20 secs a go. once it gets going its usually fine for the rest of the day.
I''ve checked fuses and relays, seems the glow plugs stay on for about 20 seconds and all are definately working with correct voltage.
I'm suspecting a fuel issue.
Tomted- sorry if i'm hijacking this thread, but it seems we are having the same problem. please let me know if you solve yours.
Thanks.
