It's a piezo variable resistor, so you could check the return voltage under varying pressures. It sees boost so use upto 1 bar or so.
Pin 1 is the variable wiper and pis 2 and 3 are the fixed potential feed. I've not got the ECU pi outs but 'think' pin 6 and 45 are the feed and pin 22 the variable return.
I have tried measuring the resistance between all 3 pins whilst pumping the tube with a bicycle pump but none of them vary - I guess that means the sensor is kaput?
Hi, no I didn't really.
I sold the car to my father who found a split pipe going from the turbo to the intercooler (or somewhere I'm not sure)
He had lots of other problems with it so wasn't that bothered asbout the turbo
