C32 serious loss of power
blackscooby said:
Car back now.
So the final inventory was :-
Vacuum pipe on air pump actuator (might be wrong with naming)
air pump
air pump relay (relay was stuck in "ON") hence why air pump expired
Intercooler pump.
Emissions were all over the place hence why it did appalling on fuel because of vacuum leak.
It's been thoroughly tested and the engineer was happy with it's performace saying it was bloody amazing.
So time will tell.
Now give it the biggest thrashing it has ever had!!!! - only to ensure everything is in order;) ;) ;).....officer
In fact ....................If worried lend it me:eek: :eek: :eek: ..................... I'll make sure everything is ok for you .......... i know a really good bit of road[they call it the 'devils highway' - the A666 between Bolton and Darwen] I know it reeeaallllllly realllllly well!!!!- travelled everyday for eight years in everything from fiestas through chevettes to 2l cavaliers and finally in fastback corollas - frightened cossies in the cav!!!;) ;) ;)
I'm away at my parents in Yorks Dales this weekend... there are plenty of "private test tracks" or near enough to give it a reasonable shake down. Infact I'll use the same roads... sorry did I say road ? test track that I use to shake down our 2 rally cars ;)
